cant push the piston to but the shows on on rear break
May 9, 2009 at 11:48 AM
JDOGGY314
MEMBER
there is a tool you buy that can help but dont try pushing it back it will damage it you have to turn it like a scew
May 17, 2009 at 2:44 PM
MPIRE73
MEMBER
Yeah bad piston usually means replace it. Correct about turning like a screw. Sometimes you can use a pair of needle nose to turn but the groves are shallow and will slip off.
