ABS makes a buzzing sound
165,000 MILES • 6 CYL • AWD • AUTOMATIC
CHUBB787
Hello, the jug where you pour the ABS fluid in, it makes a buzzing sound when ever I start the car. It keeps making the sound until I pull off. Then starts again when I slow down. Do you know what that is? Thanks
Oct 27, 2009 at 2:15 PM
CARLIFE65
  • 200 POSTS
your abs brake system has various electronic solenoids, it sounds like one of them is bad ,or the unit it gone. here are some pictures of what it looks like.
https://images.2carpros.com/forum/automotive_pictures/420105_sersor_b_1.jpg
https://images.2carpros.com/forum/automotive_pictures/420105_0900c1528008c111_1.jpg
https://images.2carpros.com/forum/automotive_pictures/420105_0900c1528008c112_1.jpg
Apr 14, 2021 at 7:34 AM
HONDA TECH 1818
  • 536 POSTS
Is your ABS modulator leaking? Your ABS modulator unit is bad, you need to replace the ABS modulator.
