1996 Acura TL 1996 Acura TL transmission trouble
FARO
  • 1996 ACURA TL
Transmission problem
1996 Acura TL 4 cyl Front Wheel Drive Automatic 98.436 miles
I have a 96' Acura TL that show the codes P0141(sensor heater circuit malfunction), P0700(trans control system malfunction), and P0730(gear ratio incorrect). What does this mean, and how much trouble am I in?
Saturday, June 6th, 2009 AT 11:09 PM
KHLOW2008
  • 41,814 POSTS
Hi Faro,
Thank you for the donation.
DTC P0141 - HO2S HEATER MALFUNCTION
This could range from loose wiring to a bad sensor or PCM.
P0700 is a code retrieved when using generic scanners. The actual fault should be P0730.
The following would give you an idea what you might be in for.
https://www.2carpros.com/forum/automotive_pictures/192750_DTCP0730_96AcuraTL25a01_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_DTCP0730_96AcuraTL25a02_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_DTCP0730_96AcuraTL25a03_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_DTCP0730_96AcuraTL25a04_1.jpg
Sunday, June 7th, 2009 AT 10:26 AM
