1995 Acura TL ABS light.
DAVID J.
Brakes problem
1995 Acura TL Two Wheel Drive Automatic
hi all,
i have a 1995 honda inspire 2.5 tl. the abs light goes off at a cold start, stays on after a short rest, and goes off again after another short rest--intermittent!!
i am showing a code of 1-8 when i "paperclip" the ecu connector. this points to low accumulator pressure. if you agree, what is the procedure for replacing the accumulator,bleeding etc.
if you think that it could be something else-- please advise me. a new modulator is a crazy priice!!
many thanks.
May 22, 2010 at 8:11 AM
KHLOW2008
  • 41,812 POSTS
Hi David, Thank you for the donation. For a bad accumulator, it is gas leakages that causes the problem and the only option available is to replace it. You can try your luck at the junkyard for a cheaper alternative. Here are the diagnostic procedures.
https://images.2carpros.com/forum/automotive_pictures/192750_DTC18ABSAcuraTLFig27_1.jpg
May 22, 2010 at 12:06 PM
DAVID J.
Hi all,
Many thanks for your reply.
I was away for a few days and got your message on my return.
Would you please resend the diagnostic diagram in larger version as I cannot read the one you sent even if I zoom into it.
Many thanks,
David.
May 29, 2010 at 7:03 AM
KHLOW2008
  • 41,812 POSTS
It is not possible to enlarge the diagrams as this site is not friendly to them. I have emailed the files to you.
May 29, 2010 at 8:05 AM
DAVID J.
Hi again,
I did not yet receive the info by E-mail.
Kindly resend to my E-mail address which is:-
Davidjosephfoy@Gmail.com,
Many thanks,
David J.
May 31, 2010 at 1:01 AM
KHLOW2008
  • 41,812 POSTS
The email did not get through.
Do you have any other email that I can use?
The original message was received at Sun, 30 May 2010 04:04:07 +0800
from 133.115.static.in-addr.arpa [115.133.224.175] (may be forged)
----- The following addresses had permanent fatal errors -----
----- Transcript of session follows -----
... Deferred: Name server: g-mail.com.: host name lookup failure
Message could not be delivered for 1 day
Message will be deleted from queue
May 31, 2010 at 2:08 AM
DAVID J.
Hi all,
Thanks for your reply.
I have no idea what can be wrong with the E- mail
address I gave you, but yes I have another E-mail.
Please resend to:- D.J.FOY@Hotmail.com.
Again,many thanks,
David J.
Jun 1, 2010 at 6:52 AM
KHLOW2008
  • 41,812 POSTS
Hi David,
I have resent the file so check your email.
Jun 2, 2010 at 2:27 AM
JEREMIAH
  • 217 POSTS
its either the relief plug on top of the accumulator is not holding pressure or a the accumulator can't create pressure. so just check the tightness of the relief plug.
i would bleed the system too just to make sure that air and lack of fluid is not causing the problem or i've seen people top off the modulator with brake fluid until the noise stops, never tried it myself so i can't say if it was a temporary solution or permanent fix
Jun 12, 2010 at 6:25 PM
