The reason your break lights won't come on when you press the break peddle is because of the break light switch. It is located behind your break peddle and the only tool you'll need is a flashlight.Go to your nearest Acura dealership and they should have that part. cost is between $7-$12. It will take about 3-5 minutes to install.
Apr 15, 2009 at 4:22 AM
