Brake light problem
LEFTHOOK
The reason your break lights won't come on when you press the break peddle is because of the break light switch. It is located behind your break peddle and the only tool you'll need is a flashlight.Go to your nearest Acura dealership and they should have that part. cost is between $7-$12. It will take about 3-5 minutes to install.
Apr 15, 2009 at 4:22 AM
JBRUCE
I have a 2002 Acura RSX TypeS (4 cyclinder) with 80,000 miles. My head lights and rear lights work but when I hit the brakes, I have not brakes lights at all including the one that is on the hatchback, what can the problem be?
Thank you for your time,
Justin
May 2, 2007 at 10:12 AM
LEFTHOOK
