Acura RSX Pulls Right Under Power
STACKOCAKES
Mileage is around 90000. I just had some suspension work done to my car and got the alignment the day after.
Now, when im on the interstate (where its most noticeable) the alignment is perfect when I'm not pushing the gas pedal down. but once i try to speed up, even just a little, it starts to pull to the right pretty bad.
It does the same thing under braking and then only time the alignment works is when its just cruising (no brake, no gas.)
Thanks for any help.
Aug 23, 2007 at 12:24 AM
BRUCE HUNT
  • 3,754 POSTS
First thing that comes to mind is a dragging brake. After driving is for a nice distance, say 5 miles or more, stop and touch each of the front rotors. Is one hotter than the other. Be careful, one might be very hot.
Aug 29, 2007 at 9:42 AM
STACKOCAKES
I found out what it was... my control arm bolt came loose when the pen fell out... i got a new pen, and its perfect now.
Aug 29, 2007 at 2:31 PM
Suggested Repair
After a long drive, carefully compare front rotor temperatures for a dragging brake. The confirmed fix was a loose control arm bolt after the retaining pin fell out; install a new pin and secure the bolt.
Conversation Summary
An Acura RSX with about 90,000 miles pulled right under acceleration and braking after suspension work and an alignment, but tracked straight while cruising. An expert suggested checking for a dragging brake by comparing front rotor heat after a drive. The owner later found a control arm bolt had loosened because the retaining pin fell out; a new pin fixed the pull.
