2006 Acura RSX Replacing brake pads..
2006 ACURA RSX
55,000 MILES • 4 CYL • FWD • MANUAL
DEEZ457
I am trying to replace the brake pads on my 2006 RSX type S and for some reason the usual caliper bolts you undo to take off the caliper just keep spinning. It looks like there's an inner bolt that may need to be kept in place while the outside bolt is spun loose, but Im not sure....help?
Apr 22, 2008 at 2:20 PM
JEREMIAH
  • 217 POSTS
you are talking about the sliding pins on the caliper right?
just use a wrench.look for a flat plate at the side of the pins,next to the rubber sleeve.you should notice it spinning with the pin's bolts when you turn.use the wrench to hold it and stop it from spinning. 17mm or 19mm- you didn't say front or rear
Apr 23, 2008 at 3:11 PM
