2005 Acura RSX shifter
79,000 MILES • 4 CYL • FWD • MANUAL
BOSNAKUS
i broke a plastic shifter componant next to the shift assembly!!! it holds the far left cable in and without it i only had 3rd and 4th gear. it had a spring on it as well. i would normally have 1-6 and revears. i wanted to know what it was called and about how much it would cost. thanks.
Jul 17, 2008 at 4:21 PM
KHLOW2008
  • 41,812 POSTS
Hi bosnakus,
Not very sure which part you are referring to so just guessing it.
If it is for the mounting of the cable, then it should be known as the shifter cable bracket.
Sorry, unable to provide the cost.
Jul 17, 2008 at 10:19 PM
