2005 Acura RSX Shift lock
GRUNWALD01
  • 2005 ACURA RSX
  • 4 CYL
  • FWD
  • 50,000 MILES
The shifter will not come out of park without using the machanical release on the shifter calom. Was wondering if there is a relay or solenoid that could be bad? Do you know of anything else that could be causing this?
Tuesday, April 1st, 2008 AT 10:08 PM
JEREMIAH
  • 217 POSTS
Check fuse #10 and #8 under the dash and listen under the shifter for the shift lock solenoid to lock or release when you step on the brake pedal.
Although. A few of the same models in the last 6 months turned out to be a faulty ECM.I would rush to see if warranty could cover the repair to save you a possible thousand or so. Good luck
Wednesday, April 23rd, 2008 AT 9:50 PM
