2005 Acura RSX headlamp
2005 ACURA RSX
55,000 MILES • 4 CYL • FWD • MANUAL
JOINGARY
how do i replace the light bulb for the low beam?
Mar 25, 2010 at 2:56 PM
KHLOW2008
  • 41,814 POSTS
Hi joingary, HEADLIGHT (LOW BEAM) 1. Disconnect the 3P connector (A) from the headlight.
https://images.2carpros.com/forum/automotive_pictures/192750_HeadlightLowBeam05RSX_1.jpg
2. Remove the rubber cover (B). 3. Pull the retaining spring (C) away from the bulb (D), then remove the bulb. 4. Install a new bulb in the reverse order of removal. Make sure the notches in the bulb align with the tabs in the headlight.
Mar 27, 2010 at 9:59 AM
