2004 Acura RSX How do you replace a starte on an 04 RSX(not
120,000 MILES • 4 CYL • FWD • MANUAL
JWP2000
How do you replace a starter on an 04 RSX(not S type)? I can't even see it looking under the hood.
Dec 7, 2009 at 2:16 AM
KHLOW2008
  • 41,812 POSTS
Hi jwp2000, The starter is located at top section of transmission.
https://images.2carpros.com/forum/automotive_pictures/192750_Starter04RSXFig16_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_Starter04RSXFig19_1.jpg
Disconnect battery negative terminal, then positive terminal. Disconnect knock sensor connector. Remove the bracket. Disconnect the wires and remove the mounting bolts and starter can be removed.
Dec 8, 2009 at 12:41 AM
