2003 Acura RSX Type S Engine Noise
CHANCE7777
My car is a 2003 Acura RSX Type S, completely stock version // No after market Modifications // standard transmission // 4 cylinder engine// 71,000 miles.
I was told by Honda after taking it in for hearing a deep knock noise when I shift gears that my short block engine will have to be replaced for $5,687.53 due to Rod Bearing // Balance Shaft Noise. Can anyone please tell me if this is needed? Is there something I can do to salvage the engine or do I absolutely have to purchase a new engine? Thank You for any assistance that is given.
Chance7777 is my ID for this site.
Oct 3, 2007 at 10:19 AM
  • 75,988 POSTS
The noise is it more of a thudding or thumping-does it intensify from idle to part throttle? To pin point the noise do a cylinder balance it will tell you where its coming from.
Who knows it might be detonation/spark knock/pinging.
Oct 3, 2007 at 2:05 PM
CHANCE7777
[quote:a8727e7607="rasmataz"]The noise is it more of a thudding or thumping-does it intensify from idle to part throttle? To pin point the noise do a cylinder balance it will tell you where its coming from.
Who knows it might be detonation/spark knock/pinging.[/quote:a8727e7607]
The noise is more of a thumping noise that does happen when the car is idling and I'm about to shift into the gear. Can this be repaired or do I have to buy a brand new engine?
Oct 3, 2007 at 6:53 PM
  • 75,988 POSTS
Sounds like main bearings it can be done underneath-just get the crank kit that's bearings/crank.
Oct 3, 2007 at 7:50 PM
