2003 Acura RSX play in hub
110,000 MILES • 4 CYL • FWD • MANUAL
SHATTERED3559
I have a 2003 Acura Rsx type S with 110,000 miles. When I jack up the front of the car, I take off the driver side Wheel, and I notice a side to side play in the hub. I have replaced my outer tie rod ends, replaced lower ball joints, replaced rotors, and replaced wheel bearings. I still feel the side to side play, and I get a steering wheel vibration at 60+ mph. I have balanced my tires also. Do you think I have to replace the drive axles?
Dec 5, 2008 at 6:27 AM
DOCFIXIT
  • 18,828 POSTS
See if play is in inner tie rod
Dec 16, 2008 at 7:32 AM
