2003 Acura RSX Hazard lights
60,000 MILES • 4 CYL • FWD • AUTOMATIC
TALLGRASS
My 2003 RSX hazard lights do not work. The pushbutton illuminates when the lights are turned on. All the turn signals work fine. Does the car have a seperate relay for the hazard lights? Where is it located? Thanks
Jun 4, 2009 at 1:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle uses the same flasher relay for both the turn signals and the hazards, however, the relay may still be at fault. If the flasher relay is OK then the hazard switch will probably be the culprit.
Jun 4, 2009 at 5:10 PM
