there's no air blowing when i turn the a/c or heat on???? i'm thinking the blower motor is dead.
Dec 4, 2009 at 9:30 AM
BLUELIGHTNIN6
✓Experienced Mechanic
check fuse and blower motor relay first before jumping the gun on replacing parts..
Dec 4, 2009 at 11:03 AM
YENG87
MEMBER
both are still fine...anything else you can think of???
Dec 7, 2009 at 6:35 AM
BLUELIGHTNIN6
the heater control panel would be next to check. you will need to remove it and inspect the wiring to it as well. if this is OK then suspect faulty blower motor.
Dec 7, 2009 at 1:32 PM
