2002 Acura RSX Rattling or clanking
2002 ACURA RSX
84,000 MILES • 4 CYL • FWD • MANUAL
JOSHUAREZENDE
When im driving my car there is a noise, like a rattling noise comming from under my center column were i shift my car. But it only makes the noise if i acclerate to fast, go over a bump, or turn to sharp. It sounds like its maybe a loose gear box, if that is a real problem. Im worried my car will break, and i dont have the money to repair any major problems. If you could help it would be a huge help.
Apr 10, 2010 at 12:20 PM
KHLOW2008
  • 41,814 POSTS
Hi JoshuaRezende,
For noise problems you would need to locate the source of the noise and from the symptom description, it should be something to do with the suspension system
Check for worn bushes and loose linkages. The stabiler bar bushes and linkages would be the most likely suspect.
Apr 10, 2010 at 2:38 PM
