Radiator Replacement Instructions?
2002 ACURA RSX
JANDERSON3
Coolant Radiator light on the dashboard just light up, do I need to add fluid to the reserve coolant tank or do I have to open up the radiator cap. Will a new radiator stop the leak if so can you show me how to change it out?
May 26, 2008 at 9:37 AM
SQM
  • 6,383 POSTS
First you will have determine where is the leak coming from. If it is from the radiator, then changing the radiator will likely fix the problem.
Please note that many times the leaks are from one of the radiator hoses or bypass hoses.
Here is a helpful article of common coolant leaks:
https://www.2carpros.com/articles/car-is-leaking-coolant
When you add coolant to the radiator, first make sure that the engine is cool and not hot. If the engine is hot it can cause the coolant to burst out of the radiator and could be dangerous.
You can also pressure test the radiator for any leaks. There is a easy to use tool that adds pressure to the radiator system to see if there is any leak. This tool can be borrowed from just about any parts store.
https://youtu.be/W8kra65m15c
Here is a helpful guide of how to change the radiator:
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
I have also attached the radiator replacement procedure as well as capacity of coolant for your RSX.
Jul 27, 2021 at 1:47 PM
