2002 Acura RSX oil consumption
105,000 MILES • 4 CYL • FWD • MANUAL
STEVNIK
My acura rsx-s is consuming about a litre of oil every 100 kms. It does not have any oil leaks and doesn t blow blue smoke from the muffler and i don t know what is going on. Can you help me
Apr 29, 2009 at 5:35 PM
MMPRINCE4000
  • 8,548 POSTS
If you are positive it is not leaking oil anywhere, then it is burning it, have a compression test performed. Lower than normal compression would indicate rings.
Run the engine up to 4000rpm in 2nd gear and let of throttle, if you see any blue smoke out exhaust then valve seals would be the cause.
Apr 30, 2009 at 12:12 AM
