2002 Acura RSX Neither heater/AC/ or defroster will blow.
2002 ACURA RSX
130,000 MILES • 4 CYL • FWD • AUTOMATIC
SCHMO75
I went throught the service manual and did the testing for the blower motor circuit....everything checks outs until you get to the fuse box where there is no power. I'm just wondering if this sounds right?
May 27, 2010 at 11:59 PM
KHLOW2008
  • 41,814 POSTS
Hi schmo75,
If you do not have power at the fuse, then you need to check/test where the problem is originating from.
That should be the first step.
Jun 5, 2010 at 9:34 PM
