2002 Acura RSX Mi car damage 2 A/C compresor coils
2002 ACURA RSX
110,000 MILES • 4 CYL • 2WD • MANUAL
LUIS1778
About 4 weeks ago my A/C stopped working suddenly. I have a Helms shop manual for my car, so I followed the troubleshooting procedure. The A/C clutch was not engaging. I traced it to a bad coil (no continuity measured by an ohmmeter).
The compressor had 168,000 miles on it, and it wasn't possible to remove the pulley / clutch without removing the entire compressor, so I just replaced the whole thing. I had the system recovered at a local shop, then installed the new compressor and new dryer myself. The new coil measured 3.2 ohms. I took it back to the same shop to have the system vacuumed and recharged. They reported no leaks, and everything seemed to be working great.
It's now 1 week later, and the clutch won't engage again. I tested the coil again, and it now show (0 ohms). The fuses not blow everything work fine Fans, Blowers, relays but my car damage 2 coils. When I leplace it the A/C coil works fine for 1 wheek them bad coil.
Looking for input from the experts:
Thanks!
Aug 18, 2010 at 10:08 AM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
There is nothing your car can do to cause an open circuit in a clutch coil. I would look carefully for any damaged plugs but other than that, I would say your just getting substandard parts. Cheaper is not always better. There's a lot of junk being sold out there.
Aug 18, 2010 at 10:20 AM
LUIS1778
[quote:43c2fbd29b="Wrenchtech"]There is nothing your car can do to cause an open circuit in a clutch coil. I would look carefully for any damaged plugs but other than that, I would say your just getting substandard parts. Cheaper is not always better. There's a lot of junk being sold out there.[/quote:43c2fbd29b]
I buy a originals oem honda parts (coil) and all the plugs are fine. I not satisfied with your answer.
Aug 18, 2010 at 10:26 AM
WRENCHTECH
  • 20,761 POSTS
I'm sorry if your not satisfied with my answer but I donate my time here for free and don't guarantee to tell you what you want to hear.
Maybe someone else will.
Aug 18, 2010 at 12:00 PM
