Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
RSX
Electrical
Alternator
Replace/Remove
2002 Acura RSX Alternator replacement
2002 ACURA RSX
148,000 MILES • 4 CYL • FWD • MANUAL
JAZZVIGGEN
MEMBER
1 POST
How do I replace the alternator.
Mar 7, 2009 at 9:50 AM
KHLOW2008
Experienced Mechanic
Hi Jazzviggen,
1. Disconnect battery negative terminal.
2. Turn auto tensioner clockwise till belting is loose and remove belting.
3. Disconnect alternator wire and connector.
4. Remove alternator holding bolts.
Mar 10, 2009 at 7:01 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
