2002 Acura RSX 5W20?
2002 ACURA RSX
87,000 MILES • 4 CYL • FWD • MANUAL
HORIAVESE
Is it safe to go with Honda's recommended 5W20 at 87000 miles or should I switch for something thicker? I've noticed some knoking noise when engine is cold. Could it be just that the valves need to be readjusted?
Thanks
Nov 17, 2009 at 5:48 AM
BMRFIXIT
  • 19,053 POSTS
Recommended is the 5w20 also every and so often an oil treatment is suggested with the oil change too
possible to take an advantage of that know by adding the recommended additive
check with your local dealer or a part store for availability
you can use it with no harm done
good luck
Nov 17, 2009 at 8:32 AM
