2005 Acura RL
2005 ACURA RL
TETHEODORE
Electrical problem
2005 Acura RL 6 cyl Two Wheel Drive Automatic
how do you check for bad ignition coil when they sit on the spark plugs
Sep 2, 2008 at 12:24 PM
KHLOW2008
  • 41,814 POSTS
Hi tetheodore, You can measure the resistance to see if it is faulty.
https://images.2carpros.com/forum/automotive_pictures/192750_DISCoilAcura_1.jpg
You can only measure the primary coil resistance across terminal 1 and 2. 0.9 to 1.1 ohms at 77 F (25 C). Replace coil if out of specs.
Sep 3, 2008 at 12:37 AM
