transmission shifts hard?
99,000 MILES • V8 • 2WD • AUTOMATIC
JERMICHEA;8
why shifts hard from 1st to 2nd and makes a noise
Sep 28, 2009 at 1:40 AM
SQM
  • 6,383 POSTS
Any time there is a shifting issue with the transmission. First item needs to be checked is the fluid level.
Make sure the transmission fluid is at the correct level and is in good condition. Low or dirty/burnt fluid and impact the way the transmission shifts. This shift issue can also be due to a clogged transmission filter.
Remember to check the transmission fluid with the engine at operating temperature.
Here is a helpful article:
Sep 21, 2021 at 3:58 PM
