Starting problems
SUPREME AUTO
Six cylinder front wheel drive automatic 212,000 miles
All fuses are good,under dash and hood. Engine turns, will not start, smelling gas, put on new crank sensor and platinum plugs, got juice (power) to all coil packs, but when i take out one of the packs with the plug, ground an pair of vise grips to the engine there is no spark jumping from the spark plug when i turn the ignition just the engine turning and smelling of gas. I am just a body and frame man. please help a brother!
Feb 21, 2010 at 1:05 PM
  • 75,988 POSTS
Check the coil's primary and secondary winding resistances and also the ignition control module.
https://images.2carpros.com/forum/automotive_pictures/12900_acura_icm_1.jpg
Feb 21, 2010 at 2:43 PM
