Replacing the starter
MONTEREYCA
Six cylinder front wheel drive automatic 148,000 miles.
Where is the starter located and what is the process to replace it? Some have commented it can be done others have said do not attempt it. let a mechanic do it.
Jul 11, 2009 at 5:19 PM
  • 55,616 POSTS
You can do it yourself, its only nuts and bolts. Here are some guides and diagrams (below) that will help you get the job done.
This is what you are in for when doing the job.
You must raise the ca safely.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Below is what it will be like on your car.
Cheers, Ken
Oct 18, 2017 at 6:18 AM
ALOHAJEFF
Six cylinder front wheel drive automatic 105,000 miles.
What is the procedure for replacing the starter?
Oct 18, 2017 at 6:19 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi Alohajeff,
Here are the procedures:
Removal
1. Ensure you have the anti-theft codes for the radio and the navigation system, write down the frequencies for the radio's preset buttons.
Note:
The PCM memory setting is needed after reconnecting the battery.
2. Disconnect the battery negative terminal, disconnect the positive terminal.
3. Raise the coolant reservoir. Remove the battery and battery base.
4. Remove the alternator belt and alternator.
5. Remove the left exhaust manifold cover.
6. Remove the left damper fork.
7. Disconnect the left suspension lower arm ball joint.
8. Remove the left axle shaft.
9. Remove the transmission stop collar, and remove the exhaust pipe.
10. Remove the front mount mounting bolts.
11. Attach the chain hoist to the engine.
12. Remove the left engine mount bracket.
13. Disconnect the starter cable and black/white wire, remove the starter.
© 2008 Mitchell Repair Information Co., LLC.
TJONES78
I need to replace the starter!
HMAC300
  • 48,601 POSTS
This is pretty involved replacing starter. I am sending a tip to make it easier but the a/C will have to be blown and recharged by doing it this way. you might think of having it done.
