2000 Acura RL Radiator Fan not working
52,000 MILES • 6 CYL • FWD • AUTOMATIC
ACURAFORME
TYVM for your time....my radiator fan isnt working. That would be the fan closest to the passanger side. The smaller fan seems to work just fine. Even when the AC is on it doesnt come on. I tried tapping the relay to see if it would come on, but to no success. Car overheats when I come to a stop, but when I start moving the temperature gauge starts to drop. Also when it overheats, its seems to not want to get in gear to drive off. Any suggestions??? Again thanks for your time!
May 4, 2008 at 10:45 AM
  • 75,988 POSTS
2000 Acura RL Radiator Fan not working: could be a problem with engine temperature gauge switch or the coolant temperature sensor-check both-
May 4, 2008 at 11:24 AM
