2000 Acura RL KEY
CLIFFCURTIS
Electrical problem
2000 Acura RL Front Wheel Drive Automatic 153100 miles
My RL wont turn over when I try to start it and in order to remove the key from the ignition I have to disconnect the battery.
May 3, 2010 at 2:11 AM
KHLOW2008
  • 41,812 POSTS
Hi cliffcurtis,
Check the underhood fuse # 39 ( 20 A ) Stop light, horn.
Underdash fuse # 20 ECU ( 20A)
Ensure horn and stop lights are working and shift lever is in P with the indicators showing when key is turned ON.
May 3, 2010 at 6:13 AM
