the mechanic is telling me I need a new brake master
123,400 MILES • 6 CYL • FWD • AUTOMATIC
BRIGITTE1219
I have taken my ACURA RL in for brake repairs. So far, the mechanic is telling me I need a new brake master because it is leaking.
Apr 17, 2008 at 6:48 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here are a few tutorials for you to view on how to replace a brake master cylinder and how to bleed the system after the repair has been made:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Since you are installing a new brake master cylinder it would be best to bench bleed the unit before installation to remove air from the new unit prior to installation on the vehicle. Here is a YouTube tutorial from our site showing how to do so:
https://youtu.be/WDxvEQrMkBg
I've attached picture steps below on how to replace the brake master cylinder and bleed the system on your car. Hope this helps and thanks for using 2CarPros.
May 12, 2021 at 2:11 PM
