1999 Acura RL fuel
1999 ACURA RL
MARCELLETTE
1999 Acura RL 6 cyl Automatic 122000 miles
My car would not turn over and my mechanic performed a check under the hood to see if fuel was pumping out. He deterimined the fuel pump needed to be replaced. The car ran for a couple of days and started to do the same thing; would not turn over. I sat for about 10min, then turned the switch on and off three times, mashed the gas and turned the switch on and off three more times. It finally cranked. Could this be and electrical problem.
Apr 16, 2009 at 3:46 AM
CARLIFE65
  • 200 POSTS
sounds like your throttle position sensor is bad.
https://images.2carpros.com/forum/automotive_pictures/420105_00136_throttle_position_sensor_2.jpg
Oct 28, 2009 at 5:57 AM
