1999 Acura RL Acura RL Window regulator/motor
PROACTIVE
1999 Acura RL 6 cyl 159000 miles
The power window doesnt work on rear passenger side. Is is possible to tell if it is the motor or the regulator w/motor to be replaced ...?
Also, without changing any of the above, is it possible to lock the window up in high position ?
Jul 21, 2010 at 3:57 AM
LEKIM707
A nylon pulley in the window regulator, gets weak with age and usually cracks, causing your problem. It's fairly common.
You can lock the window up by putting a piece of wood inside to prop it up.
Jul 21, 2010 at 7:31 AM
