1998 Acura RL engine stops while driving
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICK_H
I was driving my car and at a stop sign it stalled. After waiting 20 min. it started. Later in the parking lot it would start and stall, start and stall. Had to have it towed to garage. They got it started .....but after I drove it for a while it stalled while I was driving....was almost hit by car behind me. Once again it was towed to garage but they can't find the problem ????????
May 21, 2010 at 9:10 AM
  • 75,988 POSTS
Next time it stalls don't wait do below immediately to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
May 21, 2010 at 11:22 AM
LEKIM707
Relay Assembly Main (EFI Main Relay) is bad
Jul 21, 2010 at 7:53 AM
