1998 Acura RL acura 3.5rl
1998 ACURA RL
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMESWILLY#43
car willnot start.the engine does turn over.
Jun 2, 2010 at 7:57 AM
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 3, 2010 at 7:48 PM
