1997 Acura RL Maintenance Required Dash Light - How to Turn
1997 ACURA RL
SYNTAX26
Other Category problem
1997 Acura RL V6 Front Wheel Drive Automatic 145000 miles
I'm pretty good with cars - even built my own code reader for OBD-I (95 Mercedes), but this has me stumped.
I can't get "Maintenance Required" light on dash to turn off. I've read codes with Actron - no codes stored. I've cleared codes even though none stored.
Tried typical GM tricks - key on, gas pedal to floor 3 times.
Still can't get light to turn off.
Any advice?
Dec 8, 2007 at 7:47 PM
BRUCE HUNT
  • 3,754 POSTS
Try holding the reset to the trip odometer and while holding it turn on the key to the run position. The vehicle does not need to start. Keep holding the button until the light goes out or actually should turn green I think.
Dec 27, 2007 at 9:44 AM
