1997 Acura RL Fuel Pump
1997 ACURA RL
294,000 MILES • 6 CYL • 2WD • AUTOMATIC
JONTAVIUS
How do I check to see if the fuel pump is not working? If not, how do I install a replacement?
Apr 16, 2010 at 9:55 AM
Do you hear the fuel pump come On when you turn key on? If not check fuse and fuel pump relay, If so check the fuel pressure if its within specs.
Apr 16, 2010 at 10:13 AM
