Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
RL
Fuel System
Fuel Pump
Replace/Remove
1997 Acura RL Fuel Pump
1997 ACURA RL
294,000 MILES • 6 CYL • 2WD • AUTOMATIC
JONTAVIUS
MEMBER
1 POST
How do I check to see if the fuel pump is not working? If not, how do I install a replacement?
Apr 16, 2010 at 9:55 AM
Experienced Mechanic
Do you hear the fuel pump come On when you turn key on? If not check fuse and fuel pump relay, If so check the fuel pressure if its within specs.
Apr 16, 2010 at 10:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
