HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
RL
Fuel System
Fuel Pump
Replace/Remove
1997 Acura RL fuel pump
TIMGILLANS
MEMBER
1997 ACURA RL
1997 Acura RL 6 cyl Two Wheel Drive Automatic
how to change fuel pump
Monday, June 29th, 2009 AT 8:42 PM
CARLIFE65
MECHANIC
Drop gas tank and clean before replacing fuel pump.caution:a fuel pump is likely to fail, if installed with out a new strainer.
SPONSORED LINKS
Tuesday, October 13th, 2009 AT 10:16 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1997 Acura Rl Fuel Pump
What Is The Best Way To Go About Changing Or Repairing My Fuel Pump? Also, Is There A Way I Can Tell For Sure That It Is My Fuel Pump That'...
Asked by
adalbey
1997
ACURA RL
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
Changed Fuel Pump
Hi, A Mechanic Changed My Fuel Pump Recently And Now Everytime I Turn Left It Seems Like The Fuel Momentarily Cuts Off. It Doesn't Happen...
Asked by
bdang007
1998
ACURA RL
2000 Acura Rl Pump Relay
My Car Wont Start, Even After Replacing The Fuel Pump And Strainer, It Still Wont Work. No Electricity Is Getting Back To The Fuel Pump....
Asked by
usqity678
2 IMAGES
2000
ACURA RL
2000 Acura Rl My Car Went About Three Feet And Shut...
My Car Went About Three Feet And Shut Off. I Replaced The Fuel Pump And Still Nothing. What Else Do I Need To Check? When I Spray Starting...
Asked by
2CP-Archives
1 ANSWER
2000
ACURA RL
2000 Acura Rl
Other Category Problem 2000 Acura Rl 6 Cyl Wheel Drive Type Unknown Automatic 137852 Miles My Car Went About Three Feet And Shut Off...
Asked by
billy524
1 ANSWER
2000
ACURA RL
VIEW MORE
SPONSORED LINKS
Fuel Pump Pressure Test
Engine Not Starting
How to fix an engine that wont start
Online car repair manuals
