How do I check to see if the fuel pump is not working? If not, how do I install a replacement?
Apr 16, 2010 at 9:55 AM
✓Experienced Mechanic
Do you hear the fuel pump come On when you turn key on? If not check fuse and fuel pump relay, If so check the fuel pressure if its within specs.
Apr 16, 2010 at 10:13 AM
