1997 Acura RL DOME LIGHT
142,000 MILES • 6 CYL • FWD • AUTOMATIC
JONES1039
1 after an accident and the right rear pass door was changed the domelight remains on.did not see a door pin that usually controll the dome light.before i took the car to the body shop domelight worked fine.
2 radio displays code.even after i enter the code radio will not play.before i took the car to the body shop the radio played fine.
Dec 21, 2007 at 10:19 AM
BRUCE HUNT
  • 3,754 POSTS
Check to see if they left of the door switch or if it is out of adjustment. BUT
It sounds as though you are having residual effects of the accident. The smartest thing to do is contact the insurance company and report these problems. Many companies will stand behind the slow to surface problems for a couple of months. The impact of the accident can raise havoc with a number of auto parts not in direct contact with the collision.
Dec 27, 2007 at 1:42 AM
