1996 Acura RL Windows
180,000 MILES • 6 CYL • FWD • AUTOMATIC
PILOTFLYER
the divers side front window would not operate on my 96 RL. While troublehooting, I noticed the use was blown, replaced it and the the regulator was not blown. Replaced the regulator and now none of the windows will operate. Fuse is not blown. If the switch assembly was bad-would that stop all the windows from working?
Jul 23, 2009 at 3:19 AM
CARLIFE65
  • 200 POSTS
some time the switc assembly will go bad, inspect, your window relay , and your 40,amp fuse in the engine compartment,and the 20-amp fuse in the passenger compartment.
https://images.2carpros.com/forum/automotive_pictures/420105_6_1.jpg
Oct 12, 2009 at 2:06 PM
