1996 Acura RL starting
1996 ACURA RL
155,000 MILES • 6 CYL • FWD • AUTOMATIC
CBONAMICO
The car cranks when starting but not turn over. We replaced battery & alternator. The security red light does flash intermidently, could that be it?
Jan 19, 2008 at 4:40 AM
JEREMIAH
  • 217 POSTS
the car is equipped with an immobilizer system to prevent theft.you should see the key shaped,green indicator in the dashboard on top of the shift selector
the light should blink twice then turn off;if you have a programmed key. if it keeps blinking,then you have to get your key programmed by the dealer.
red security light is not from the factory.sometimes you can disable aftermarket alarms by locking then unlocking the car with the key from the driver's door.
Jan 20, 2008 at 5:11 PM
