1996 Acura RL no heat
1996 ACURA RL
150,954 MILES • 6 CYL • FWD • AUTOMATIC
XEHOIBIHU
I got no heat for my car after adding bottle of head gasket fix that it sell at autozone. Does head gasket fix liquid to seal up heat core? Just changed thermal start, still has no heat. please I need help this problem.
Jan 26, 2010 at 9:53 AM
KHLOW2008
  • 41,814 POSTS
Hi xehoibihu,
If the leakages is from minute cracks, the sealer might work, if the leaking point is a gaping hole, it is not going to work.
Did you bleed the cooling system?
Jan 27, 2010 at 7:36 AM
