1993 Other Acura Models MALFUNCTION ENGINE INDICATOR LIGHT
1993 ACURA
VISTAGIRL
Engine Mechanical problem
1993 Other Acura Models Engine Size unknown Two Wheel Drive Automatic 125000 miles
MALFUNCTION ENGINE INDICATOR LIGHT what does that mean on a 1993 acura vigor. the vigor is a 5 cylinder
Mar 5, 2008 at 1:37 PM
  • 31,937 POSTS
Hi there,
If the engine light is set, the ECU has located a problem in the engine management system, this is held in the memory as a code , which your mechanic can extract and read, each code is for an individual component so diagnosis is made easier. Get the code read first.
Mark (mhpautos)
Mar 10, 2008 at 5:14 PM
