1996 Acura NSX a/c compressor
1996 ACURA NSX
34,500 MILES • 6 CYL • 2WD • MANUAL
96NSXBILL
a/c compressor will not shut off --
pulled the a/c clutch fuse and the compressor shuts down, but when reinstalled the clutch will not disengage no matter what setting the interior controls are on -- also cleaned the fuzz from the interior temp. sensor -- any ideas -- bill
Jan 20, 2010 at 2:56 PM
F4I_GUY
  • 3,302 POSTS
The relay is most likely shorted to on. Try swapping relays to see if that helps.
Sep 29, 2010 at 4:30 PM
