malfunction indicator on 2001 MDX
BACHIEF
I have a 2001 Acura MDX with113,000 plus miles. It is an automatic. It is a water cooled 4 stroke SOHC 6-cylinder V6 gasoline engine. The malfunction indicator light came on. I checked the gas cap and it was tight. We have trouble codes 1740 and 1456. What could be causing our problem? Is this something we can fix ourselves or do we need to take it to a dealer? Thank you for your help
_________________
Oct 8, 2007 at 11:12 AM
DAVE H
  • 13,383 POSTS
Please could you supply first letter of DTC as they are important to working out the exact fault
P 0 1 0 1
1 2 3 4 5
1st digit
P = powertrain
B = Body
C = Chassis
2nd digit
0 = Standard in all makes of vehicle
1 = Manufacturer specific
3rd digit
1 = Emission management
2 = Injector circuit
3 = Ignition
4 = Auxiliary emission
5 = Vehicle speed & idle control
6 = Computer & output circuit
7 = Transmission
Nov 6, 2008 at 3:38 AM
