Had car back at dealer 3 times to fix air conditioning problem. 1st time they thought i might be leaking refrigerant and added some. 2nd time found nothing wrong even though I was complaining car was not getting cool enough. 3rd time, air conditioner was only blowing hot air. At this time they replaced the compressor and clutch. Working fine for about 2 days now, finding that car again not getting cool enough, but noticed that it is happening mostly when car is idling in traffic. Once I accelerate, car is starting to get cool again, but not as cool as it should be. I have the temp. turned lower than 60. At that point it should be freezing and it is just comfortable. I also noticed that if I press slightly on the automatic window buttons on the driver side door, the air speed changes slightly.
Jul 26, 2008 at 2:21 PM
