2004 Acura MDX removing front and rear rotors
2004 ACURA MDX
SGARRITY
Brakes problem
2004 Acura MDX 6 cyl Four Wheel Drive Automatic
How do I remove the front and rear rotors so I can have them turned? I'm instauling new pads.
Apr 25, 2008 at 11:42 AM
JEREMIAH
  • 217 POSTS
first, make sure you have the right tools.
you need 12mm,17mm,19mm sockets; large hammer; impact driver; #3 phillips bit and piston compressor.
take the wheels off, use the impact driver and hammer to remove the two screws holding the rotor, remove the 2 bolts that hold the caliper, remove the 2 bolts to remove the brake pad's bracket, remove the rotor, you might have to use the hammer; compress the caliper's piston and assemble in reverse order.
pump the brake pedal before you start the car.
Apr 30, 2008 at 4:11 PM
LUNENBURGER
  • 14 POSTS
Great info thanks...
Aug 22, 2008 at 2:21 PM
