2004 Acura MDX Rear Hatch wont lock or unlock
2004 ACURA MDX
ZFAY
Electrical problem
2004 Acura MDX 6 cyl
The rear hatch on my 04 MDX wont lock or unlock with either the keyless remote or the lock button on the driver side door? I thought it was the actuator so I replaced it, that didn't work. Any ideas? Could it be the door sensor - does that supply power?
Feb 1, 2010 at 3:39 PM
KHLOW2008
  • 41,814 POSTS
Hi zfay,
Most likely cause is an open circuit between the actuator and control unit.
Feb 2, 2010 at 3:52 AM
ZZZZZZZZZZZZZZZZZZZ
Check the wires that connect the rear hatch to the body. On an 01 it is on the top left. Pull the rubber cover back as far as you can and see if there is any breached wires. It will look as if they were cut. Hope that helps!
Jul 30, 2010 at 5:10 PM
