2004 Acura MDX Heated seats
CHUCKSTER
  • 2004 ACURA MDX
  • 6 CYL
  • AWD
  • 149,000 MILES
Can you tell me where the fuse for the driver's side seat heater is? If it is not a blown fuse, any other hints on what to check would also be appreciated.
Tuesday, December 15th, 2009 AT 7:06 AM
KHLOW2008
  • 41,814 POSTS
Hi Chuckster,
Driver's under dash fuse/relaybox, fuse # 4 ( 7.5 A ) Hot when ignition switch is turned ON.
Passenger underdash fuse/relay box fuse # 14 ( 20 A) Hot at all times.
If the passenger heater is working correctly, this is not a problem with the fuses or relays as they uses the same circuit.
Check the wire connectors under the seats for proper installation/connections.
It could be a faulty switch.
Sunday, December 20th, 2009 AT 12:04 AM
